Cromwell MkIV Kartonowa Kolekcja
- Jorzik
Hello.
In October, I started the construction of a new tank. This is a model from Kartonowa Kolekcja of the British Cromwell MkIV tank in the 1/25 scale.
I will use a laser skeleton and caterpillars for construction.
I started the work by gluing the frame and cutting out the coverings.
- Jorzik
Re: Cromwell MkIV Kartonowa Kolekcja
Hello.
The hull was made. I also made the suspension of the main chassis.
So far, everything fits very well.
- Jorzik
Hi
Here is the next portion of photos from the model building.
I glued the elements of the main suspension, and the outer covers.
I made the front wheels and the rear idlers.
In the next step, I cut out the elements of the tower and then pasted them.
- Jorzik
Hello
Construction of the Tower takes, I made almost all of its elements.
I made also boxes and other small items of equipment.
- Jorzik
Hi
I gained some momentum and made a set of supporting wheels.
I mounted the fenders and attached bolts and rivets to the hull.
Small elements have also reached the hull.
- Jorzik
Hi.
The work getting close to the end. I installed all wheels and most of the items on the hull.
- Jorzik
Hi
It seems that all the elements have been made. Tracks under construction.
- Jorzik
Hi
My new tank model is ready. Model very well developed, all parts fit accurately. The tracks I made with laser cut elements.
I hope that my new model will appeal to you.
All photos you can find in Gallery section.
